PSA: Cheap BB5 road...
[Closed] PSA: Cheap BB5 road calipers
[#3702013]
And a few other cheap bits:
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=31349 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=31349[/url]
Posted : 22/02/2012 1:04 am
Hmm - specifies "rear" - any reason I can't stick on on the front?
Posted : 22/02/2012 10:02 am
afaik it would be simply a change of adaptor mount.
Posted : 22/02/2012 11:08 am
HG - yes. Last ones I got came with both R and F mount, it's implied these won't of course.
Posted : 22/02/2012 11:09 am
Will these be compatible with std v brake levers?
Posted : 22/02/2012 11:32 am
No, canti or road levers.
Posted : 22/02/2012 11:34 am
Cheers Al. Even better 🙂
Posted : 22/02/2012 12:10 pm
Why wouldn't they work with standard v levers? Is one version shorter pull length than the other?
Posted : 22/02/2012 3:08 pm
 cp
the road ones use the shorter cable pull of road sti's or older canti leveres.
The MTB ones use the longer pull of v-brake levers.
IS 160mm rear as on CRC will fit post mount front 160mm, or will mount on the front with the IS adaptor & use a 180mm disc in most cases (there may be, in some cases adaptor-fork clashes)
Posted : 22/02/2012 3:38 pm
