PSA - Airdrop outle...
PSA - Airdrop outlet bargains
[#12907252]
Some good deals to be had for the 27.5 brigade plus some SRAM brakes, CCDB shocks, etc.
https://www.airdropbikes.com/collections/outlet
Posted : 28/07/2023 1:29 pm
frogstomp reacted
 Creg
Thanks for the PSA
That ex demo Edit v4 is tempting
Posted : 28/07/2023 1:33 pm
Ta - good price on the G2 RSCs.
Posted : 28/07/2023 2:37 pm
https://www.airdropbikes.com/collections/outlet/products/rockshox-sdlx-coil-ultimate-shock
Does anyone know how much difference 2.5mm of extra stroke would make to a Norco Sight? I've already fitted a Cascade link which bumps the travel slightly.
I might check the clearances when I get home and spend some money.
Posted : 28/07/2023 4:06 pm
Does anyone know how much difference 2.5mm of extra stroke would make to a Norco Sight? I’ve already fitted a Cascade link which bumps the travel slightly.
Divide your existing amount of travel by the existing shock stroke, then multiply by the new shock stroke.
Posted : 28/07/2023 4:22 pm
52.5 stock shock gives you 150mm travel, so a longer shock would take you to about 157, if nothing hits the seat tube (you could mod your existing shock by removing a spacer)
Friend has done this - he also has the cascade link, he says the Cascade link and longer stroke combined make for 162mm. His is an alu frame, not carbon - would be very careful to check clearance to make sure nothing is making contact when you are are bottomed out and the frame isflexing
Posted : 28/07/2023 4:30 pm
And even if you think it's fine, you may still find black marks on the back of your seat tube.
Posted : 28/07/2023 4:37 pm
