proper vice-like se...
[Closed] proper vice-like seat clamp.....idea's?
 ton
[#9634303]
i need a proper vice like seatclamp for my solaris.
the hope qr one it can with is crap. cant get it tight enough to stop the post slipping. and i dont want to over tighten it and bust it when a shut the lever.
idea's please.
Posted : 29/10/2017 5:46 pm
Salsa.
One of these came with my old Soul. Post never slipped in the 6 or 7 years I was using it.
Posted : 29/10/2017 5:47 pm
Do you need to drop it? If not, you can turn that hope one into a bolt-up pretty easily.
Posted : 29/10/2017 5:50 pm
 ton
not to drop it. just a bog standard bolt one.
didnt want to use the hope one. was gonna sell it once i had a solution.
Posted : 29/10/2017 5:57 pm
Is it a Thomson post ? Are you using carbon paste on the post ?
Posted : 29/10/2017 6:01 pm
 ton
not a thomson. it is a race face.
Posted : 29/10/2017 6:03 pm
I couldn’t get a Thomson to stay put in my Soul, but have a Raceface which does. Lots of carbon paste on it, and Hope clamp with a bolt (you can buy a bolt converter for the qr ones)
Edit : it’s a spare post in my case for when the Reverb is broken and away for repair !
Posted : 29/10/2017 6:05 pm
Salsa Lip Lock are spotty Dog Tony.
Posted : 29/10/2017 6:06 pm
 tdog
Likewise for a Salsa liplock, nothing but the best and in a multitude of wicked colours too, oooooo.
Posted : 29/10/2017 6:11 pm
The bolt-up adapters are only a few quid. Got mine from All Terrain in Saltaire.
Posted : 29/10/2017 6:13 pm
+1 for the Salsa....makes the Hope look like the POS it is !
Posted : 29/10/2017 6:14 pm
Ton remove the qr and stick an m6 bolt through? Had no end of trouble on my solaris with a hope qr. Removed the skewer and shoved a bolt through and it's perfect. Make sure rhe clamp is the correct way round! Split lines up with the split 🙂
Posted : 29/10/2017 6:16 pm
I had a hope one on my charge filter, with a thomson post.
It didn’t slip, but i always felt that i was putting a lot of strain on the bolt to actually tighten it, so i switched to a thomson clamp, much better.
Im a hope fan btw, but not of their seat clamps.
Posted : 29/10/2017 6:29 pm
 km79
See if you can find a double bolt seat clamp. CRC used to do a Brand X one which was only a few quid and it was solid, ideal for bigger guys.
http://www.chainreactioncycles.com/brand-x-double-bolt-seat-clamp/rp-prod8213
Posted : 29/10/2017 6:31 pm
Another version of the two bolt seat clamp has two different diameters, one to clamp the Seat tube and one to clamp the post. I’ve not used one but I do know they’re available and cost around £25.
Posted : 29/10/2017 6:40 pm
 ton
A bit lighter.
http://www.xcracer.com/shop/viewproduct.php?productid=351
Posted : 29/10/2017 7:18 pm
 ton
a bit lighter........you take the piss matey.
like a bit lighter makes a differance to a 20 stone lump...... 😆
Posted : 29/10/2017 7:28 pm
Every bit helps mate. 😛
Posted : 29/10/2017 8:29 pm
