Procore or B+ ?
[Closed] Procore or B+ ?
[#7172585]
I have a HT 29er and like the idea of running lower pressures (more comfort at the back and more grip at the front). So, I could go for procore or fit some 650B wheels with 2.8" tyres. As far as I can see it's six of one and half a dozen of the other. Both add a bit of weight. Both cost a few hundred quid and both allow you to run similarly low pressures. I'd give the nod to B+ on the aesthetics, but procore is a lot simpler. I just add the inner tubes to my existing wheels/tyres as far as I can tell.
Is there anything I've missed?
Posted : 04/07/2015 11:43 am
29er tubeless? Low pressures fine, more grip, comfier.
Posted : 04/07/2015 9:20 pm
650b+ as then you can have both wheelsets as options for different rides
Posted : 04/07/2015 9:26 pm
Procore is aimed at teh gnarly riders so extreme they need two tyres per wheel were as b+ is aimed at attention seekers desperately looking for the next big thing that they think will take their riding to the next level...
Posted : 04/07/2015 9:28 pm
Waits for Procore+.
Posted : 04/07/2015 9:43 pm
Never tried either (but thats probably true of most people) but do have a fat-bike. I recon pro core should feel little different to conventional tubeless. I've only once managed to snakebite a tyre beyond sealing and find the limit of low pressure is when it gets all squirmy and feels horrible. Fat tyres on the other hand are just plain bonkers fun 🙂
Posted : 04/07/2015 9:47 pm
Which frame lets you put that in the back?
Posted : 04/07/2015 9:49 pm
Genuinely confused as to when a 2.3 29er Magic Mary doesn't provide enough grip for anyone. When do you actually need more?
I can run mine down to about 16psi on 35mm wide rims easily, but have them a bit higher because they feel like crap too low.
Posted : 04/07/2015 10:31 pm
How low do you want to go? Does normal tubeless not work, how much grip are you not getting?
Posted : 05/07/2015 3:43 am
Like the idea of procure as I run lower tubeless pressures and occasionally catch a rim but I think my crests are too narrow 😥
Posted : 05/07/2015 8:04 am
What Rickon said. I think the 29er tyres go lower in pressure than is useful anyway.
So I vote for B+, also because it's claimed to give monster grip anyway. Wouldn't mind trying 2.8 tyres out myself, but not going to rush into anything.
Posted : 05/07/2015 8:16 am
