Problems with my al...
[Closed] Problems with my alfine in deep snow...
That's a great link coastkid. I don't think I'll get the hacksaw out just yet but if I keep the frame I have I'm going to want to get disk mounts fitted at some point which would be the ideal time to get an s&s coupler fitted as well.
Posted : 09/01/2010 9:46 pm
Update on the alfines first ride today, on some of the points others have mentioned i didn't really notice the weight on the back end,there is a slight shifting delay but i did not find this a problem, also as mentioned you cannot shift under heavy load but then i never do this with a derailuer setup.
I did find it good that you can shift when stationary but the main thing i need to get used to is the backward shifter as i am used to SRAM triggers, all in all very good and should only take 15 to 20 mins to swap back to SS
Posted : 10/01/2010 3:48 pm
Since the OP I've given the EBB a tweak once, oiled the chain 3x and had the bike washed at Bonty24/12.
And it's still shifting perfectly...
Posted : 29/11/2010 1:28 pm
Page 2 / 2
