Problems with Crown...
[Closed] Problems with Crown on Giant Reign
[#239649]
i am trying to change forks on my Giant Reign and am having difficulty in unscrewing the crown which sits on top of the stem.
it is an FAS headset with a Giant cap above the stem and speaking to my lbs they tell me it is a 4mm allen key fitting. However, when i try to unscrew with the 4mm there is too much movement and it looks like it would round off the hole. If i try to use a 5mm it is too big.
Does anyone know if there is a 4.5mm allen key or has any other solutions?
Posted : 24/01/2009 9:56 am
4.5mm allen keys do exist, as do imperial sized ones. Most likely the first one, although most are 5mm
Posted : 24/01/2009 10:42 am
Perhaps you've rounded out the 5mm hole with your 4mm tool? Can you do that?
I wouldn't think it's anything other than 5mm to be honest.
Posted : 24/01/2009 10:46 am
Which year and model?
I just took the fork off a 2008 Reign 1 and there were no odd-shaped bolts involved, if that helps.
Posted : 24/01/2009 11:45 am
Are you sure it's not a torq?
Posted : 24/01/2009 12:06 pm
it is a 2007 Reign 0.
i have definitely not rounded it out with the 4mm. The 5mm would be impossible to get in there. The stem bolts and all other fixings are the standard 5mm.
I will try a torq fitting to see if it works and if not then look at getting a 4.5mm allen key
Posted : 24/01/2009 11:16 pm
