Was out on the bike yday when landed a small jump the fork just lost compression. The fork was set at full 150mm travel with no lock out on and normal pressure, the fork now just sags the first two inch of travel and can easily be moved up and down by hand for the first two inches, there is no visible oil leaks or seals bust. Anyone help or know the problem or quick cure? Or is it TF Tuned time.
Thanks James
probably just the o ring between bottom and top air chamber .Theres loads of vids for servicing revs online and once you get inside theyre quite straight forward realy. Just watch the vids before you start and youl be fine !! besides if it goes wrong its no skin off TF`s nose to put them back together for you !!
