Problem with hope p...
[Closed] Problem with hope pro2 evo.
 Mole
[#7583151]
Hi all,Recently had a hope pro2 built up. Bought the hub as 142x12 as that's the only hub they had in stock with a sram xd freehub fitted.Bike is 135 so thought I'd try 10x135 so got said adapter's at the same time.Just fitted the cassette and it doesn't fully fit onto the freehub because the 10mm adapter is stopping it. Anyone know if I need a different adapter for sram or if 10mm won't work with sram 11speed? Know its the adapter because I've just but some standard quick release adapters on and it's fine. Cheers Mole.
Posted : 16/01/2016 8:06 pm
Had to get a specific hope xd 12mm adaptor for mine, its got a larger chamfer / stepped section to allow the cassette clearance. Sure its the same with 10mm. You could modify the one you have with a file /drill, it only needs about 0.5mm off.
Posted : 16/01/2016 8:19 pm
 Mole
Yeah was thinking that's all that's needed(file action) to allow the cassette to fully engage. Cheers blairc70.
Posted : 16/01/2016 8:44 pm
