Probably daft 9spd ...
[Closed] Probably daft 9spd > 10spd Chain ring / front mech question.
[#2748219]
If making the change from 3x9 to 2x10, do I need to change front rings, or just drop the big ring, stick a bash guard on and set the limit on front mech to middle ring?
Or are these bits specific to 10 spd too?
Thanks.
Posted : 13/05/2011 1:44 pm
Yep that'll be fine. Chain rings only care about the inside diameter of the chain, which is te same for 8,9,10 speed. Also, you won't 'need' a bash ring, mech should keep the chain on. Of course you can have a bash if you want though.
Posted : 13/05/2011 1:49 pm
Good stuff, thanks goldfish, just what I thought / hoped.
Posted : 13/05/2011 2:12 pm
