Pro4 + Arc27 27.5 +...
[Closed] Pro4 + Arc27 27.5 + DT Comp + brass nipples = g?
[#8195347]
Anyone know the weight of above wheel set with XD?
Posted : 07/12/2016 1:24 am
Not boost!
Posted : 07/12/2016 1:26 am
Thats a pretty random question, but if you go to teh DT Swiss website, launch the spoke calc, pick parts of a similar nature (eg same rim diameter, same holes number, j bend/SP etc.) then you'll get the weight for a DT version, then plug in the hub and rim weights from the Hope and Easton websites and you're basically there... as much as you trust the weights you use that is.
Posted : 07/12/2016 6:12 pm
