Pro evo conversion
[Closed] Pro evo conversion
[#5189932]
Hi
Does anyone know if a 15mm bolt through Hope Pro Evo 2 can be converted to 15mm?
Unfortunately I can only find a QR to 20mm bolt through
Posted : 26/05/2013 2:04 pm
Not sure if I can make sense of your question, but a Pro2 evo will work with all of the usual standards ie 9mm qr, 9mm bolt through, qr15, and 20mm just by changing the adaptors.
Posted : 26/05/2013 5:53 pm
If its a pro2 evo hub yes! You just need this.
http://www.chainreactioncycles.com/Models.aspx?ModelID=30152
Posted : 26/05/2013 5:54 pm
Oops sorry just realised I made a typo. I have a 15mm bolt through pro 2 evo and need to convert it to 20mm. Does anyone know if that's possible?
Posted : 26/05/2013 10:53 pm
Yep, it's just different inserts.
It's only slightly more involved because the adaptors have a circlip thing to hold them in - rather than just push in/ pull out like the 15mm and QR ones.
Posted : 26/05/2013 11:01 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=10237 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=10237[/url]
I'm sure someone has a set they will sell you
Posted : 26/05/2013 11:02 pm
Thanks a lot.
Did see those ones but assumed that they only do QR to 20mm, due to the description. Good to know that they'll convert my 15mm also
Posted : 26/05/2013 11:07 pm
