pressing headsets c...
[Closed] pressing headsets cheaply
[#2991510]
any one used one of these?
ebay.co.uk/itm/HEADSET-PRESS-INSERTION-TOOL-LOW-COST-HANDLE-/110718285099?pt=UK_Spots_Leisure_Cycling_Tools_RepairKits&hash=item19c752f52b#ht_798wt_883
any good or a bit of a bodge?
Posted : 28/07/2011 7:40 pm
[url= http://www.ebay.co.uk/itm/HEADSET-PRESS-INSERTION-TOOL-LOW-COST-HANDLE-/110718285099?pt=UK_Spots_Leisure_Cycling_Tools_RepairKits&hash=item19c752f52b#ht_795wt_889 ]here?? this one I assume[/url]
not much to go wrong that I can see but why not just use a hammer tbh. Never damaged any frame this way- never tried it on a carbon one though
Posted : 28/07/2011 7:45 pm
 nbt
for £7 you could make one from a piece of threaded rod and some nuts. I did and it's done loads of headsets
Posted : 28/07/2011 7:51 pm
Me neither. But I have used a hammer on a cabin frame. It's fine. 🙂
Posted : 28/07/2011 7:59 pm
you could, but for £7 all the work has been done, doesn't look too bad to be honest.
bit of wood and a hammer. great on alloy frames but steel is a bit springy and tend to fight back
Posted : 28/07/2011 8:00 pm
I made one from threaded rod, nuts, big washers, bits of wood but if you have £7 and a job, go for the eBay number. Much easier.
Posted : 29/07/2011 12:23 am
I use a bench vice, not attached to a bench.One cup at a time. Faultless.
And useful for pressing and holding many other things too.
Posted : 29/07/2011 12:28 am
 Gunz
I've always hammered mine in with no problems but to be honest that E-Bay one looks good value and well made for 7 quid.
Posted : 29/07/2011 12:29 am
i've one off ebay and it works sweet as a nut. works much better than an hammer anyway!
i even use the same all thread at work,but for the sake of 7 notes could be arsed to make one.
Posted : 29/07/2011 12:49 am
Threaded rod, nuts and washers is much better than a hammer - and something I've happily used with expensive headsets on carbon frames. That ebay thing is a ready-made threaded rod and nuts, but better, and I'd suggest pretty good value at that price.
Posted : 29/07/2011 12:54 am
I got one of those, bugger to keep things aligned when you start tightening things up, but basically great. Cheap, does what it says on the tin.
Kev
Posted : 29/07/2011 5:00 am
