Pressfit 30 Bottom ...
[Closed] Pressfit 30 Bottom Bracket
[#5811587]
Long story short, was lucky enough to get a warranty frame replacement recently however new frame is PF30 and kindly the distributor said he had some adaptors to allow me to reinstall my current threaded BB, happy days 😀
However the frame turned up with adaptors already in and they need to be out as gear cables all run internally through BB
Have done a bit of googling and founds vids of fitting PF30 BB but none on removal, have had a look on Park Tools website but am still a bit confused on what I need for removal and refitting.
Would rather get the tools and do it myself as long as they aren't hugely expensive 😳
Assuming I will be able to reuse the adaptors?
Posted : 31/12/2013 7:14 pm
Assuming its the same kind of press fit as bb30, I remove mine [b]carefully[/b] with a flat head and a rubber mallet so that I dont damage the bearings too much and can reuse them.
You can buy removal tools, the park tool one for bb30 is ~30quid I think which put my off..
edit: after a 30 second google I found this,
seem pretty inclusive.
second ninja edit: Found [url= http://www.parktool.com/product/pressfit-bottom-bracket-bearing-tool-set-bbt-90-3 ]these[/url] [url= http://www.parktool.com/product/bottom-bracket-tool-set-for-bb30-bbt-30-3 ]tools[/url]
Posted : 31/12/2013 7:20 pm
maximusmountain, I've found similar things but I don't think what I have has any bearings, it appears to just be a plastic? item which gives me a thread for my existing BB complete with bearings to screw into, not sure if that makes any difference though?
Posted : 31/12/2013 7:25 pm
Id rather use a tool then to not dent the plastic to make sure the threads would be ok, you would also have to use a press to put it back again anyway. worth taking it to the lbs to get them to do it quickly?
Posted : 31/12/2013 7:36 pm
The adapters are exactly that. They give you a conventional BB thread..
Whack them out gently! Screw in your bb cups and press the assemblies in with a headset press or similar.
Posted : 31/12/2013 7:56 pm
Careful, they may be loctited in.
Posted : 31/12/2013 8:04 pm
