Need to fit a BB92 - ideally I need just the 2 installation bushings from here - but I already have a standard headset press and wanted to use that.
[url] http://www.bike-discount.de/en/buy/press-fit-bottom-bracket-bearing-tool-set-bbt-90.3-42905 [/url]
Any cheap source for these (and no I don't want to use the hammer/block of wood method!)?
washers.
or the park park press with bb92 adapters
there's your two extremes, £1 or £100 🙂
Superstar tool works well. Full tool but cheaper than getting just the spacers elsewhere.
Edit - my google powers may have been weak looking for just the spacers though.
Wheels Manufacturing, 6806 open bore presses at £5.99 each, available via Madison from LBS, part no.WMS6806OB
If you remove the inner plastic top hat from the old cup and flip it over, you have the perfect tool to locate on the outer flange of the new bearing.
This can be used with a press or hammer to fit the new one.
Thanks all. gravity-salve - I don't have an old bb to remove.
@coatsey - must be these then?
[url] http://wheelsmfg.com/bb86-bottom-bracket-cup-drift.html [/url]
Look like the ones, the code I found was on Madison's site.
Ah. Bugger! You will next time, hang on to the cups 😉
