Press Fit BB remova...
[Closed] Press Fit BB removal tools, home bodge options?
[#6824931]
I have a confounded press fit BB which has only lasted since May and is now scrap. I don't want to buy to Park tool for removing it because it is almost £40.
Is anyone either offering a cheap alternative or is there a home bodge for it? It's a PFBB30.
Thanks
Posted : 31/01/2015 4:20 pm
Hammer & drift always works for me.
Posted : 31/01/2015 4:35 pm
Fsa make a drift for removal and then I used my headset press to re install.
The fsa drift is very cheap
Posted : 31/01/2015 4:38 pm
Oooh I get to be the first:
Posted : 31/01/2015 4:42 pm
Superstar one for £25? It's still more than seems reasonable but I've got the BB92 version and it works really well.
[url= http://www.superstarcomponents.com/en/bb30-removal-tool.htm ]Superstar Linky[/url]
Might not be as nice as the Park tool one but it's not exactly a high-use item, though maybe a few times a year if all your BBs last like the one you're replacing 🙁
I will try and find the FSA one. I'm not too knowledgeable about press fit bbs, will the dridft take out the plastic casing too?
Euain- as per Al's post I won't buy from superstar because they are underhand, thieving, moral-lacking arseholes who pedal shoddy and dangerous goods with no conscience.
Posted : 31/01/2015 6:37 pm
Mine are just sealed bearings...not sure what you mean by plastic casing..
Posted : 31/01/2015 6:43 pm
I'm assuming he means the sram pf30 plastic cups. Yes the tool will take them out. I popped the bearings out and reused mine with a bit of loctite
Posted : 31/01/2015 6:55 pm
Yes, it is a SRAM bearing with plastic cups. I have another BB that came with the frame that appears to be some bearings and some spacers.
Posted : 31/01/2015 6:58 pm
