Press fit bb? recco...
[Closed] Press fit bb? reccomendations?
[#5304193]
After going through 2 XTR ones in the last year what else is left to try?
Thanx,
Max
Posted : 04/07/2013 12:31 pm
New hope one?
Posted : 04/07/2013 12:32 pm
Oh,by the was gonna try the Hope but apparently won't fit to Anthem X29!:(
Posted : 04/07/2013 12:33 pm
really? reason?
Posted : 04/07/2013 12:38 pm
[quote=Turnerfan1 ]Oh,by the was gonna try the Hope but apparently won't fit to Anthem X29!:(
Bigger hammer?
Posted : 04/07/2013 12:41 pm
 cnud
Gusset make a decent PF30 for £35ish available from Bikescene
Posted : 04/07/2013 1:34 pm
intrigued to know why hope wont fit?
Posted : 04/07/2013 2:08 pm
Well,
Someone posted on here a week or so ago and took an Anthem X29 into 18 bikes and was told it wouldn't fit.
They had to ring up Hope to confirm it.
Apparently there is some ridge inside the shell so it will not line up.
If anyone can confirm this I would be grateful.
It would be my first choice.
Thanx,
Max
Posted : 04/07/2013 3:34 pm
Chris king.
Posted : 04/07/2013 4:00 pm
Confirmed, a colleague had one in last week, there's a gusset(for want of a better description) in the centre of the shell that prevents some BBs from being pressed fully home.
Posted : 04/07/2013 5:07 pm
Ah,
Forgot about Chris King.Bet its pricy though.
I rang Hope up and they confirmed there's a problem with the Anthem X29 and there pressfit bb.Trying to work round it so we should know in due course.No availability of that new XTR as yet so have ordered a Enduro pressfit bb from BETD so I will see how that fairs.Seems rather cheap at 30 quid but bearings are replaceable (bought some spare ones).Seems replaceable bearings are the order of the day which mite mean they wear out quickly? We shall see.At least I don't have to buy the cups.
Thanx,
Max
Posted : 04/07/2013 5:13 pm
The Hope one isn't ready yet...my PF30 is well on the way out but Hope isn't ready to sell to punters yet...about another 4 weeks apparently...so if anyone has them just now...how? (and how much?)
Posted : 04/07/2013 5:27 pm
I'am talking about BB92 pressfit which Hope make and are available (they just don't fit Anthem X29).
Hope don't make one for BB30.
Thanx,
Max
Posted : 04/07/2013 6:18 pm
to be fair I have found on the anthem the BB71 / 91 does not quite fully push home flush on the drive side fraction under 1mm.. on my anthen the BB shell is not symetrical
Posted : 06/07/2013 10:15 am
My LBS is reccommending the Rotor - apparenetly they have on that accepts 24mm XT cranks straight off. Haven't tried it myself as my planned Spearfish deal fell through.
( http://www.rotoruk.co.uk/PressFit.html)
Posted : 06/07/2013 11:17 am
Hope have pushed back on the PF BB for another month at least...
I've just installed a Wheels Manufacturing PF30..seems to be ok so far and very easy to install.
Posted : 15/07/2013 10:00 am
Just to say that my lbs (a Hope premier dealer) have tried fitting a UN71-41 equivalent Hope pressfit bb into my 2012 Trance frame - it definitely doesn't fit. 🙁
The reason is that the bb shell has a smaller I/D (approx. 36.5mm) in the central part between where the cups are pressed in than the O/D (approx. 37.5mm) of the extended part of the non-driveside cup of the Hope bb. I'm guessing that the same applies to the Anthem frame as well.
The extended part of the non-driveside cup is the bit that the head of the threaded inner sleeve mates with (it passes through the non-driveside and threads into the driveside cup). Apparently Hope designed it this way so that they could use one inner sleeve design for MTB (89.5-92mm) and road (86mm) pressfit bb shell widths.
I'm going for the Rotor version instead, although it doesn't have an inner sleeve.
Posted : 31/07/2013 5:04 pm
Token..
Posted : 31/07/2013 6:01 pm
