Pre glued patches a...
[Closed] Pre glued patches anyone used these ?
[#4891444]
Just looking online for pre glued patches,i normally buy lezyne,which are mega,but not cheap,just wondered if anyones used these ??
http://www.ebay.co.uk/itm/6-Raleigh-Pre-glued-Puncture-Repair-Patches-kit-like-Skabs-and-Super-Patch-/121066704459?pt=UK_Spots_Leisure_Cycling_Tools_RepairKits&hash=item1c30234e4b
Posted : 21/02/2013 10:37 am
Lezyne are worth it imo. Some of them have been on for years I forget they're there until I change the tyre
Posted : 21/02/2013 10:42 am
 Pook
I've used them for years! Never had a problem for as long as I can remember. In fact, I patched a snakebite with two park patches last week and they're holding despite some step riding and rocks.....
Posted : 21/02/2013 10:44 am
Tried em all
Nothing ever beats good, old fashioned, rema Tip-Top puncture kits
Posted : 21/02/2013 10:50 am
Lezyne and Tip top kits both what i normally use,so i guess ill stick to them,if ya pardon the pun...thx guys.
Posted : 21/02/2013 11:01 am
Lezyne seem best of a bad lot from my experience. Unless you prep it they have been get home only for me really.
Posted : 21/02/2013 11:03 am
I used Lezyne for ages then changed to Park.
Park are nicer IMHO and work well sealing tubeless tyres from the inside if they have a cut or small split.
Posted : 21/02/2013 11:15 am
As above I've found park to be good, quick to apply and small enough to to keep in a wallet
Posted : 21/02/2013 11:42 am
If you are a serial tube repairer/miser like me (record: 13 patches on one tube 8) ) then proper old fashioned vulcanised ones all the way. The pre-glued ones are great for a quicker fix on the trail but i find they don't stay stuck on forever and have had slow-ish punctures that turned out to be the old glued patch.
Posted : 21/02/2013 11:44 am
Used, Topeak and Park Tool glueless patches and recommend either of them.
Posted : 21/02/2013 11:48 am
I carry Park ones with me out on the bike (and have used them a couple of times). However they aren't feather-edged like 'normal' (decent quality) patches so not great on a road bike where you can sometimes feel the Park patch whilst riding.
Posted : 21/02/2013 12:37 pm
If you are a serial tube repairer/miser like me (record: 13 patches on one tube ) then proper old fashioned vulcanised ones all the way. The pre-glued ones are great for a quicker fix on the trail but i find they don't stay stuck on forever and have had slow-ish punctures that turned out to be the old glued patch.
I'm finding this, especially on road tubes that have a higher pressure. I can see air bubbles appearing under some older patches and its only a matter of time before they work their way to the end.
So I've gone back to the 'old ways', replace the punctured tube and repair the punctured one when I get home with rubber and a patch.
BTW Ive use/used Park ones.
Posted : 21/02/2013 12:49 pm
Twaddle! I suppose you can ride over a crisp packet and tell what flavour they were too... 🙄
Actually no it's not twaddle it's my actual experience you dimwitted muppet - I'm normally shit at telling the difference between minor changes on the bike but it's like if you've got a bit of chewing gum stuck on the tyre, there's a distinct vibration from it (at least there is if it's directly on top of the tube and you're running lightweight thin tyres like Schwalbe Ultremos.
Posted : 21/02/2013 12:52 pm
That's because the glue they use doesn't actually harden, so they'll always be liable to move. Proper patches with a tube of glue are far preferable IMHO.
Posted : 21/02/2013 12:55 pm
You'd have to be riding on glass, with 180psi and hemorrhoids... Get well soon 😉
Posted : 21/02/2013 1:08 pm
