Hi Guys
Can anyone point in the directions of some online instructions for this? I know TF used to have them but I can't locate them anymore.
Thanks
Posted : 26/10/2015 12:50 pm
Take the Talas gubbins out and replace with float top cap?
Or is there more to it than that?
Posted : 26/10/2015 2:14 pm
Off the top of my head...Deflate, remove lowers, remove air side top cap, unscrew talas cartridge. Using the supplied circlip, fit the alloy cup that holds air shaft/negative spring in place, fit air shaft/negative spring assembly, pour 5ml of fox fluid on top of seal head, replace top cap, inflate and then reassemble lowers with correct amount of oil.
It's pretty straightforward.
Posted : 26/10/2015 3:23 pm
