PRANG! SMASH! BANG!...
[Closed] PRANG! SMASH! BANG! (Front page content)
[#5565800]
And what exactly happens in the event of a crash spinning your bars around?
Bye bye top tube? 😕
Posted : 02/10/2013 9:30 am
Should come with free stick on rubber bumpers.
Posted : 02/10/2013 9:34 am
Just put the stem on the right way up and it will be fine 😉
Posted : 02/10/2013 9:39 am
 Rio
the Flatforce is intended for riders having a hard time finding a good position on longer-travel 650b and 29in bikes
A bit of blue-sky out-of-the-box throw-it-at-the-wall-and-see-what-sticks thinking here, but what if instead you made the wheels smaller, say 26"? Oh, wait...
Posted : 02/10/2013 9:40 am
But then the 'decals'* would be upside down! 😉
*Stickers, obviously.
Posted : 02/10/2013 9:42 am
There are pages other than the forum? Wow, learn something new every day
Posted : 02/10/2013 9:46 am
The bars/levers of all my bikes hit the top tube if the bars spin around in a crash, even with positive rise stems.
Posted : 02/10/2013 9:48 am
I may get that and stick it the proper way up. Ideal for my dodgy back, can get rid of all the spacers then too
Posted : 02/10/2013 9:49 am
Prezactly. I've tweaked my levers up a smidge so they don't on one of mine, but the bars'll hit first every time in that stem.
Posted : 02/10/2013 9:52 am
Looks like that stem has had one too many Stellas
Posted : 02/10/2013 9:54 am
What's that you say about [s]decals[/s] stickers being put on upside down?
Cock up in the design = marketing opportunity!!!
Posted : 02/10/2013 9:57 am
That'd go nicely with my 50mm risers.
Posted : 02/10/2013 10:14 am
 LoCo
Want that 44mm one, frankenbike currently has a flipped 45mm on anyway, working on some bump stops for top tube 😉
Posted : 02/10/2013 10:15 am
A bit of old inner tube and some duct tape works. It looks gash, but it works 🙂
Posted : 02/10/2013 10:26 am
 LoCo
😀 True, but can't be see with that on the 'nice' bike 😉
Posted : 02/10/2013 10:27 am
[i]working on some bump stops for top tube[/i]
Maverick used to do some nice ones.
Just put some BikeShield on the TT
Posted : 02/10/2013 10:35 am
So does the stem!
Posted : 02/10/2013 10:38 am
 LoCo
Will match the rest of the bike 😉 and rider
Posted : 02/10/2013 10:40 am
Why not mount a normal stem between fork crown and lower headset bearing and be done with it?
Posted : 02/10/2013 10:53 am
It's a matter of leverage though.
For the same force at the bar end, there will be more pressure on the frame the closer the contact point is to the stem. That's why Lefties use a bump stop.
It looks like a solution to a problem that doesn't exist to me, but if it did exist, designing some sort of upside down riser bar would be a better solution.
Posted : 02/10/2013 11:03 am
[i]upside down riser bar[/i]
a Lower?
Posted : 02/10/2013 11:07 am
Sort of.
If you just turn a riser bar upside down,the grip parts will be angled downwards, a bit like sports motorbike bars.
I was thinking of something that drops from the middle,then rises up again slightly at the ends.
Posted : 02/10/2013 11:19 am
Brewer's Droop for your bars 🙂
Posted : 02/10/2013 11:30 am
What we actually need it he bars to be directly mounted onto the crown of the forks. This way we can use much larger wheels and look even dafter.
Posted : 02/10/2013 11:38 am
Theres a photo of a russian made track bike with bull horns protruding from the fork crown. Looks a bit odd as obviously it stil needs a conventional top tube and headset!
Posted : 02/10/2013 1:48 pm
All solved by getting a bike that fits. Short people on big wheels look as ridiculous as I do on 26"
Posted : 02/10/2013 1:53 pm
Sure you don't mean this;
Posted : 02/10/2013 1:54 pm
rOcKeTdOg - Member
All solved by getting a bike that fits. Short people on big wheels look as ridiculous as I do with this beard"
POSTED 6 MINUTES AGO # REPORT-POST
Posted : 02/10/2013 2:00 pm
No conventional top tube or headset on this one - though clearly the "forks" still have to pivot somewhere.
It seems incredible that bike is over 20 years old.
Posted : 02/10/2013 2:34 pm
 igm
And bizarrely I saw a one of those Lotus bikes on a bike rack in Annecy this summer. Or a very good copy.
Posted : 02/10/2013 3:58 pm
Is it wrong that I thought this thread was going to be about the Diana film?
PS - could easily solve the problem by putting some spacers underneath 😀
Posted : 02/10/2013 4:02 pm
Sounds like one of brant's godawful designs... 😉
Posted : 02/10/2013 4:25 pm
[i]The bars/levers of all my bikes hit the top tube if the bars spin around in a crash, even with positive rise stems.[/i]
leverage doesn't come into it. The grips/levers will hit the cross bar before the stem, and they'll hit half way down. Lefties have a bump stop because a riser stem or bars set-up could well have the levers/grips clearing the top tube, allowing the fork to hit the frame.
Posted : 02/10/2013 4:28 pm
Houns - Member
rOcKeTdOg - Member
its gone James, keep up at the back!
Posted : 02/10/2013 5:42 pm
