poxy creaking again...
[Closed] poxy creaking again!
 jedi
[#2999785]
its deffo NOT my chris king 1.5 headset. i can feel it in the stantion/crown. 🙁
i just want forks that work
its ti 55 time i think
Posted : 31/07/2011 11:35 pm
stantion/crown, steerer/crown interface I suspect. You can normally make them creak/click by holding the front wheel between your knees & trying to rotate the bars. Difficult to do much with it - may be warrenty, my 32 vanillas do it, I can stop it for about 6 months at a time by putting the bike upside down, applying thin chain lube to the stantion/crown interface, applying heat with a hot air gun to the crown & vigerously pushing/pulling the lower legs with the wheel removed, reapplying lube & heat until the creaking stops.
Posted : 01/08/2011 7:31 am
Short term...oil soaked into crown/stanchion junction?
Posted : 01/08/2011 7:40 am
marzochhi fork? I had this with a set of dirt jumpers on the tandem - windwave assured me it was OK but I could feel movement in the stanchion / crown joint so had the top assembly replaced
Posted : 01/08/2011 7:59 am
I'm getting similar with my SIDs - should I be concerned as opposed to just annoyed?
Posted : 01/08/2011 8:03 am
 jedi
they never used to do it so i dont want to risk it failing
Posted : 01/08/2011 8:06 am
Hmmm. Think I'll take 'em off the bike & see if I can get 'em to do the same then - at least I'll get a better look.
Posted : 01/08/2011 8:08 am
 jedi
new crown and lowers and its sorted 🙂
Posted : 03/08/2011 11:04 pm
Mine turned out to be an end cap in a cable stop 😳
Posted : 04/08/2011 3:03 pm
+1 - just greased all my cable ends and problem gone - for now.
Posted : 04/08/2011 3:15 pm
New one on me - for a rear creak under load/high torque are knackered jockey wheels - My top pully's ceramic bushing was not there - totally disintegrated! Off tangent sorry!
Posted : 04/08/2011 3:17 pm
just to get this cross threaded, any creaking i get is blamed on the gobi saddle...
Posted : 04/08/2011 3:20 pm
