Powertap G3 - no Wa...
[Closed] Powertap G3 - no Watts?
[#8126286]
Any ideas?
Its still a registered device on Trainerroad via ANT+ dongle, I've changed the battery just in case but it doesn't show any data when I turn the pedals.
Thanks
Posted : 25/10/2016 1:30 pm
Pedal harder?? 😉
But seriously, my ANT+ dongle seems to need to be taken out and plugged in again a few times for the PC (Zwift specifically) to play ball so maybe that? Could you not just try unpairing and re-pairing the G3 from scratch? Seems like a pain but if it works...
And finally, you *definitely* put the coin cell in the right way round obviously? I had to pretty much take a photo of mine to convince myself I was putting it in the right way 😳
Posted : 25/10/2016 1:38 pm
Yep done all that. It wouldnt show up in Trainerroad with no signal, no ANT+ connection.
Its is there, just no readings.
Posted : 25/10/2016 1:41 pm
Do you have a garmin? Can it pair with that?
Is it actually pairing? If you remove the sensor from TrainerRoad list and try and re-find it, does it find it?
Posted : 25/10/2016 1:46 pm
Not much use i'm afraid, other than pointing out that an FTP of 0W is probably an all time low - can only improve from there 🙂
Posted : 25/10/2016 1:50 pm
Good point, I'll try.
Yes.
The garmin didn't, so I surmised it must still be the battery. I bought a new one locally, works straight away.
I guess the replacement battery has "expired" in some way.
Posted : 25/10/2016 2:52 pm
I had a CR2032 "expire" on me in the summer when it exploded on a particularly warm day. The scorch mark on the window took some scrubbing to get off! I don't think I'll buy the *really* cheap ones off eBay any more :-\
Posted : 25/10/2016 2:58 pm
Torque tube might be dead 🙁 I had 2 in 6 months, G3 was unreliable crap
Posted : 25/10/2016 4:35 pm
PowerTap C1 chainrings here - worked fine till I had to change the battery now completely fails to work. It's going back..
Looking at Quarq cranks instead. Anyone got any experience?
Posted : 25/10/2016 5:39 pm
Ive used Quarq cranks for 4 years with no issues at all, good battery life and good readings.
Posted : 25/10/2016 5:43 pm
I've had no issue with the G3 for two years, and this has turnwed out to be a duff replacement battery.
On the other bike I've had an Infocrank on it for 8 months, which really has been fit & forget.
Posted : 25/10/2016 6:30 pm
Curious about the C1. Can't be that old. Definitely worth dropping their UK service guys an email.
Posted : 25/10/2016 7:12 pm
It was great up till it went bonk.
I'll post up what's happened to it as as soon as I get it back..
Cool.
Posted : 26/10/2016 9:41 am
