Powder Coating
[Closed] Powder Coating
[#1633152]
Does anyone know of Powder coating frames in the Buxton, Derbyshire area?
Posted : 22/05/2010 4:28 pm
No one have any ideas?
Posted : 22/05/2010 9:05 pm
From personal experience I would go to your LBS, ask if they can do it for you, or if they can recommend someone. I once got a frame done by a powder coating company and it was absolute bobbins (bead from the bead blasting inside the frame), I recently got a frame done by Bob Jacksons in Leeds, proper job £70 single colour.
Depends what kind of finish you're after, you could always just strip the frame and spray can it yourself using a galvafroid primer and then a hard hat top coat.
Posted : 22/05/2010 11:57 pm
I seem to recall that 18bikes in Hope use a powdercoater that they recommend
Posted : 23/05/2010 8:20 am
 robh
I believe Hope use [url= http://www.windridge.co.uk/content.php/410 ]Windridge[/url] in Kent they were a LOT cheaper when I used them 2 or 3 years ago.
Posted : 23/05/2010 8:54 am
Its worth checking with a powder coater then argos of Bob jacksons, as a cycle specific place are likely to do a better job,
I took a frame in to be powder coated and explaned which bits needed to be protected etc, and they did't take enough care, I now pay the little extra and get Bob Jacksons to do it,
Posted : 23/05/2010 8:58 am
Ah cool looking good It's just an old frame at the back of the shed I don't want to spend loads on it, just enough to get it up and running
Posted : 23/05/2010 10:07 am
Used Triple S in Bingley for various motorbike bits and they are top quality + quote about £50 for a mountain bike frame. Here
http://www.triple-s.co.uk/prices.htm
Posted : 23/05/2010 2:42 pm
I could get it done matt black for nowt at our place. Only black mind and you'll have to strip it.
Posted : 23/05/2010 2:51 pm
Takisawa sent you a email
Posted : 23/05/2010 6:43 pm
