Posting bars.Who to...
[Closed] Posting bars.Who to use
[#6409394]
Am i right in thinking that royal make sting you for posting say a 720x 50mm package.If so who do you use.
Cheers all.
Posted : 12/08/2014 6:39 pm
I use Hermes - tad under a fiver for tracked and insured postage.
Posted : 12/08/2014 6:40 pm
Try yodel if you don't want them to get there.
Posted : 12/08/2014 6:43 pm
It can go as a medium parcel with Royal Mail as long as it's tubular shaped, under 90cm in length and under 8cm diameter.
Posted : 12/08/2014 6:44 pm
myhermes, £2.69 for under 1kg with £50 compo, - add £1 for a signature on delivery, don't put in the true dimensions, no one cares or checks
Posted : 12/08/2014 6:51 pm
Cheers for the replies.Sounds like it's myhermes
Posted : 12/08/2014 7:39 pm
+another for MyHermes.
Posted : 12/08/2014 7:44 pm
+ 1 for Myhermes. Used them a good bit recently for the heavier / bulkier stuff.
Once you are set up its so easy to arrange a delivery, they can collect from your door too for an extra 20p.
If you add a 'safe place' you don't even need to be in when they collect 🙂
Posted : 12/08/2014 8:55 pm
