I'm trying to figure out brake and fork set ups. Basically i have some Hope mono4 (black/gold) 180mm is mount brakes, which i want to put on a new build, but the forks are likely to be post mount (i haven't decided on those yet). Then there's the wheels to throw into the equation, i've been looking at possibly some centre locks...
So can i get this thing to work? I can find a plus 20mm adapter which would allow a 200mm rotor, but the rotors are all 203mm???
Help, please.....
Jack
I've just done same thing using mini monos. Works fine, you just need to add a couple of small flat washers between the posts and the adapter to allow the 203 to spin.
I've got an adapter you can have for £6 posted, though you'd need to find some bolts somewhere as mine didn't come with any.
Sounds like a bit of a bodge 😕
It is, but it works.
Hope do 200mm rotors if you ask.
Any idea on how much custom rotors are?
They have them in stock, standard or floating, same price as the 203mm rotors. Go into a Hope stockist they should be able to get you some.
