Post mount frame to...
[Closed] Post mount frame to flat mount disc adaptor now exists...
 Joe
[#10539876]
Has anyone tried the above adaptor? Looks to be what i've been looking for and will allow me to run the brakes I want on my road frame!
piccy
Posted : 18/03/2019 4:33 pm
Got a link to the place where it can be bought?
Posted : 18/03/2019 4:50 pm
Thats quite 'special'.
Posted : 18/03/2019 8:43 pm
 aP
I saw that a couple of months ago, seems ok.
https://www.assolutions.ca/flat-mount-caliper-to-post-mount-frame-photos/
Posted : 19/03/2019 8:54 am
 Joe
What is "special" about it?
Posted : 19/03/2019 1:59 pm
Looks like someone got busy with a brakepress there, neat solution...
https://www.assolutions.ca/product-category/adapters/
$40 CAD is about £22 plus shipping and tax... wonder if they need a UK importer?
Posted : 19/03/2019 2:17 pm
Waiting for the cheap copies in eBay. I'm glad flat mounts can be retro fitted
Posted : 21/03/2019 7:37 pm
Ace,
Been pulling my hair out looking for them!
Posted : 13/04/2019 9:51 pm
Thought I would revive thread and give a heads up.
It doesn’t seem that assolutions are posting to UK atm due to Pandemic.
After a bit of reseach/luck I found the good folks at spokeydokeybikes in Yorkshire have a batch of FM to PM adapters in.
PSA, Merlin have a good deal on GRX groupset 35% off as of today.
Posted : 12/04/2020 7:27 pm
UK and European Importer - Spokey Dokey Bikes in Yorkshire.
Posted : 19/06/2020 3:03 pm
Thanks Chris - will they be on your website?
Posted : 19/06/2020 6:29 pm
 aP
Is Spokey Dokey a bike shop? I can't tell from the website. Where are the adapters available from?
Posted : 19/06/2020 8:43 pm
Did anyone track one of these down?
Posted : 11/05/2021 8:23 am
Theres another brake mount standard?
Why!!!???
Posted : 11/05/2021 8:36 am
Wake up at the back!
Posted : 11/05/2021 8:49 am
Yes, 12mnths ago and it’s been fine.
https://www.spokeydokeybikes.co.uk/
Might not fit all frames but they give a schematic-drawing thingy so as you can check sizes.
Posted : 11/05/2021 8:52 am
Warning if you use one for the front, minimum disc size is 180mm. Fine is you're running something that's a bit lardy but could be a problem if the fork engineering is not up to the job. (Shimano's recommendation is max 160mm disc for its road brakes).
The only downer is that the calliper securing screws are plated steel and rust as soon as they sniff water. Budget for some better machine screws.
Posted : 11/05/2021 9:01 am
Does anyone do an IS to FM adaptor?
Posted : 11/05/2021 9:03 am
Thanks onzadog! I was starting to make plans around these, and you've just reminded me that they aren't the adapters I'm looking for.
Posted : 11/05/2021 9:12 am
Warning if you use one for the front, minimum disc size is 180mm. Fine is you’re running something that’s a bit lardy but could be a problem if the fork engineering is not up to the job.
I've never really understood this. Surely, if your brake is powerful enough to lock the wheel or throw you over the bars, the stress on the fork will be the same regardless of the rotor size. The caliper will have more leverage on the brake mounts, but it will also have exactly the same extra leverage on the rotor. Those two will cancel each other out if you are braking at the same level of deceleration.
Posted : 11/05/2021 9:15 am
 Sven
I bought one of those adapters from Spokey Dokey bikes in August last year, they were great to deal with, and I am using it with a 160mm rotor on the fork.
Posted : 11/05/2021 9:52 am
they aren’t the adapters I’m looking for.
Could you go IS<postmount<flatmount? In a double adapter way?
Posted : 11/05/2021 9:56 am
I was thinking that, but no need!
https://www.assolutions.ca/shop/adapters/flat-mount-adapter-for-is-frame/
Posted : 11/05/2021 11:27 am
I've messaged Spokey Dokey to see if they stock the IS adapter.
Posted : 11/05/2021 12:14 pm
I couldn't find an answer when I discovered the Shimano warning. Could be increased heat on the pads and calliper causes a problem. I've not died yet with my 180mm rule breaking (touches wood just to be certain).
Posted : 11/05/2021 2:51 pm
Bigger disks should cause less heat stress.
My guess is that they don't want people to do big DH runs on lightweight XC forks, but I've always ignored the max disc size and run 200 mm front discs on all my bikes. Only problem is commuting on icy roads.
Posted : 11/05/2021 3:14 pm
