Post Mount Forks us...
[Closed] Post Mount Forks using IS brakes?
[#590813]
Hi looking at Magura forks with post mounts but the brakes I have are magura marta 180 mm IS mounts, will I be able to get an adaptor or are the systems incompatiable?????
Posted : 29/05/2009 7:01 pm
You can get mounts such a Hope's HBSM20, but will need a 20mm bigger disc unless you're already using an adapter.
Posted : 29/05/2009 7:22 pm
Wouldn't this work?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=21525 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=21525[/url]
You can't run a 160mm IS caliper/rotor set up on a PM fork. You have to up that to 180mm.
Posted : 29/05/2009 8:41 pm
thanks dave gr that look like that will work
Posted : 29/05/2009 8:44 pm
