so I’ve got what I think is a 2017 Rockshox Pike to go on my hardtail. I believe it has a 180mm disc post mount as standard. Struggling to get my head around what adapter I need to go from that to a 200mm disc fitting.
Has anyone got any links to what I need at all - the cheaper the better obviously! I’ve got a sram guide caliper going on if that makes a difference - the later style brake caliper with the bleeding edge port.
I'm not an expert, but I reckon this is the one:
https://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-post/rp-prod13747
I think the 160-180 will do it. You need to add 20 mm.
https://www.chainreactioncycles.com/shimano-mount-adaptor-front-post-to-post/rp-prod13747/a >
Yes - as Hols2 post.
I screwed this up recently. The Shimano adaptors look cheaper and simpler than Hopes (and also have the benefit of being clearly labeled)
Note the warnings from the reviews that those parts on CRC are cheap because they don't ship with bolts. For the +20 shimano adaptor you need extra long bolts to replace the standard ones that come with your brakes.
(+23 are offset so you use 2 sets of standard bolts)
