Are they standard? I'm looking at buying some second hand Hope Minis, do I have to have brake specific adapters for my bike or will any work? I'm pretty sure I've used generic ones with other brakes. Spec is as follows:
Front:
IS fork, 203mm disc, Post caliper
Rear:
IS frame, 185mm disc, IS caliper
Cheers!
Depends I use a shimano one and another none hope one but my hope adapters wont work with my Avids till I adapted them with an angle grinder.
I assume Hope are quite wide and therefore most others will be ok
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13720 ]FRONT[/url]
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13736 ]REAR[/url]
Cheers! Gonna give the LBS a call and see what they've got in, I need 'em by Saturday...
