My SS bike suffers a bit from flex in the frame and forks when out of the saddle.
A 9mm DT RWS front skewer has helped the front and was thinking a rear may help too.
The dropouts are horizontal and the rear hub is a Pro 2 EVO.
With the right hub end caps a 135x10 DT RWS should fit ..... non?
Yeah, I think so, I've got the screw in bolts on my pro 2 evo which needed a change of axle. Phone Hope to check.
On my previous frame - Trek 4 series, it was as noticeable as the upgrade to RWS on the fork.
Yep, although if you run a qr at the moment, you'll have to change the hub axle.
Pro 2 can be converted to 10mm bolt up axle as per the trials hub. Will be stiffer than a 10mm through axle.
https://www.wiggle.com/hope-pro-2-evo-mtb-rear-10mm-bolt-in-conversion-kit/
@GFJ yes I was aware of those and that would be ideal but for the fact I can’t deal with the need to rebuild the hub 😬
Also looking to keep the weight down ☺️
Pro2 Evo is Just change of end caps.
I've used DT Swiss axle and Superstar, both make an improvement.
