Positive and negati...
[Closed] Positive and negative air
[#231281]
Ok in my rock shox manual it says if i have more negative than positive air the small bump sensitivity will be better. My positve is set at 140 psi so how much more negative do i put in or do people keep them at the same pressure?
Posted : 20/01/2009 10:44 pm
plus/minus 5 psi is usual i think
Posted : 20/01/2009 10:53 pm
 dobo
check the manual but i think i recall it saying no more than 15 more in the negative.
if you put too much in you loose travel and it all goes wrong.
also recommended preassure on my sids is too high for my weight.
Posted : 20/01/2009 11:02 pm
