Play in rear shock
[Closed] Play in rear shock
[#2801145]
I have play in my rear shock of my '04 Enduro.
It's a bit of up and down play.
I presume something needs replacing, but I'm not sure what.
Play is probably about 2mm or so.
Posted : 29/05/2011 8:04 pm
It'll just be the bushings that are worn.
£20 for a new set of bushings
http://www.mojostore.co.uk/acatalog/Fox_Rear_Shock_Bushing_Kits.html
And a 'take it to the bike shop to get the new bush fitted' or do it yourself if you're able to extract the bush.
Posted : 29/05/2011 8:09 pm
It's a pearl 3.1 on it just now - no idea if it's been serviced ever before. I presume it needs roxk shox busings.
If I replace the whole rear shock with something new, a DT Swiss XM180 (I think it is) what do I need for mounting it?
Posted : 29/05/2011 8:18 pm
Pretty sure the Pearl damper is non serviceable if that helps.
What size do you need?
Posted : 29/05/2011 8:23 pm
190x50 or I think I can get away with 200x50.
I think the can can be serviced but that is about it.
I've seen a few shocks on ebay, but I like to keep my costs to the mininum with my bikes and feel a 130 quid shock is overkill, but very tempting.
Posted : 29/05/2011 8:28 pm
