Plastic Syringes - ...
[Closed] Plastic Syringes - Where from?
 cp
[#759808]
I need to lube the foam rings on my fox fork, and reckon the easiest (and cleanest, it was a bit of a mess last time pouring the oil on!) way to get oil onto them is to use a plastic syringe with a wide opening. I've had them before for brake bleeding etc, but can't remember for toffee where I got them from. Anyone any ideas?
Cheers, Chris
Posted : 04/08/2009 6:26 pm
you can get large syringes from [u]mole valley farmers[/u]
Posted : 04/08/2009 6:27 pm
 Bush
Your local chav druggie !!
Failing that, your local Chemist might be worth a try.
Posted : 04/08/2009 6:38 pm
eBay 🙂
Posted : 04/08/2009 6:39 pm
I got a pack of 10x20ml for just this purpose for £3 from "medsave" on ebay, the postage was half the cost (but much cheaper than local chemist types).
Posted : 04/08/2009 6:45 pm
ebay
Posted : 04/08/2009 6:46 pm
I just went down to the local health centre pharmacy to get mine.
Posted : 04/08/2009 7:06 pm
vets. Don't bother asking a druggie, they normally don't use the big ones you want for a bike (although the fioam rings only want 5ml each so you might be okay)
Posted : 04/08/2009 7:48 pm
In my case
ebay for the syringe
local car parts place for plastic tubing
Posted : 04/08/2009 7:53 pm
Just go to Boots and ask for some some small syringes, the oral hygiene ones they do are good for squirting oil into the foam lube rings.
Posted : 04/08/2009 8:16 pm
 Hip
Vets for me. £1 for 2 30ml ones...
They didnt believe me when I said I wanted them to bleed my bike brakes.
It was only after I said I didnt need the needles they sold me some... 😀
I got a sheep catheter from countrywide farmers. It is a huge plastic syringe and long tube so perfect for bleeding brakes.
The guy at checkout was only slightly confused why I was buying one 😀
Posted : 04/08/2009 8:32 pm
I re-use the veterinary ones, I'm on "Dry Cow" at the moment
Posted : 04/08/2009 9:06 pm
