Planet X free range...
[Closed] Planet X free ranger cabling advice
[#12031577]
Just got a free ranger frame, 3 ports on the front top and bottom one with gear cabling guides I assume it doesn't matter which is used for front and rear as they both come out at BB and then rear re enters frame after BB.
Disc routing, need to disconnect one end of hose, for those that have built one is it easier to fit hose from front end of frame and coict to calliper or feed through from calliper end and reconnect at sti?
Ta
Posted : 10/09/2021 12:25 pm
Word of advice,run a full outer through the frame for the rear derailleur cable.Planet X run a bare cable through the plastic guide over the bottom bracket which over the miles digs into the guide and affects gear shifting.
Posted : 11/09/2021 8:37 am
@devonboy same for front shifter as well then, or I wonder if I can run a bit of outer for both cables over the plastic guide, thanks for the tip
Posted : 11/09/2021 11:54 am
