Pitch upgrades
[Closed] Pitch upgrades
[#6352635]
Afternoon all, any one got any experience if upgrading a Specialized Pitch?
I have a 2010 model, which I love, love , love and am loathed to change it. I can afford to put some new Pikes on it, and am also considering a CCDB Air on the rear. To my mind, this would make it a whole "new" bike. Switching to 650b or 29'er at this stage doesn't appeal. As this fork/shock upgrade is likely to cost a fair bit, plus I could add an XT groupset and new wheels, would I get better value by simply buying a new bike instead?
Thanks in advance...
Posted : 20/07/2014 6:25 pm
Are new pikes available with 1 1/8th steerers? If so then crack on. Pitches are ace.
Posted : 20/07/2014 6:31 pm
Better off buying a new bike than changing everything
Posted : 20/07/2014 6:36 pm
Bregante - Member
POSTED 20 MINUTES AGO # REPORT-POST
Rushes to check RS website.....
Posted : 20/07/2014 6:52 pm
Upgrade it but don't spend a fortune as you would benefit from a new frame with the now standard tapered headtube, 142mm rear and 27.5/29 wheel compatibility eventually.
Posted : 20/07/2014 7:01 pm
Pretty sure new Pikes only come in tapered steerer.
What forks do you currently have? Speak to a suspension specialist like Loco, see if the forks and shocks can be tuned or upgraded? Might be more cost effective?
Wheels are always a good place to spend money on too. What do you currently have? You could either get a lighter yet also strong pair or just a lighter set of wheels for the days you're taking it easy and just getting in the miles and put the other more durable pair when you're giving the bike a good hammering.
I'm not too bothered about fancy groupsets they all seem to work well as far as I am concerned. I have one bike with Deore and LX stuff and one bike with XT. Both of them change gear just as slick when i push a shift lever. Yes the XT feels nicer but on a limited budget I'd rather spend it on wheels or forks.
Posted : 20/07/2014 7:14 pm
 bol
I put 150mm revelations, roval traversees, an RP23 and sram x9 on mine IIRC. It was nice, and I always liked the geometry, but I would buy something new these days and get the benefits of seven or eight years' development.
Posted : 20/07/2014 7:31 pm
Revs or Sektors only I'm afraid. New Pikes aren't available in straight steerer.
I'd buy a Pitch frame if they had a tapered headtube as I love them, but I have a Specialized Camber with straight headtube and it sucks not being able to get hold of decent new forks for it.
Posted : 20/07/2014 8:20 pm
I ran mine almost as a mini DH bike. Lyriks, coil rear shock, fat rims. It was ace for hooning around on:
However, although I regularly used it for all day epics, it wasn't too great for it and I would be beat by the end of a 30 mile ride. Came into its own on uplift days, or at Aston hIll, the alps, pushing up snowdon and hooning down the rangers path.
If I still had one I'd find some 2nd hand Marzocchi RC2ti forks, a CCDB air, some stans flows tubeless and put some 1x10 gearing on with an expansion ring. You could hit the sweet spot then between DH ragger and a pedal around all day ride.
Pitchs were ace and I was gutted when Spesh stopped making them.
Posted : 20/07/2014 8:49 pm
ditto.. I bought this frame for the alps. Whacked a coil shock, coil lyriks, tubeless with 2.5 minion and a narrow wide chainring
ace downhill
Posted : 20/07/2014 8:55 pm
