Hi guys,
I'd like to upgrade rear suspension on my 2011 Pitch Comp (with Rock Shox Ario
it's either too hard/not responsive on smaller bumps or, with lower pressure, tends to bottom out on 2" drops + some other issues). I'm 5'11“, 155 lbs, I mostly ride fast single tracks with lots of roots , moderately rocky, 4-5“drops.
Since suspension performance is defined by suspension design as well as proper shock tune I was wondering if anyone has has come across a compression ratio/vertical travel curve (or maybe even some further data) for the bike so I could choose a suitable off-the-shelf shock. Or, alternatively, which shock tune (Rock Shox Monarch or Fox Float shocks) would you recommend for this bike?
Cheers!
Janez
