Pinnacle Arkose wit...
[Closed] Pinnacle Arkose with a flat bar? Jameso are you there?
[#8097211]
Anyone run their arkose with a flat bar rather than drops? Does it ride ok?
Posted : 08/10/2016 6:12 pm
Coincidence- I was looking at the evans website the other day to see if they had a flatbar version of the Arkose.
I used to run a flat bar on my Surly Steamroller, it was fine. I changed the stem- I can't remember if it needed to be shorter or longer I'm afraid! I think it might have been longer with the flatbar...
Posted : 08/10/2016 6:15 pm
Hello.
The 2017 Neon disc. It's very close in almost every way, +20-25mm reach aside. Takes 40mm tyres, has road BB drop and a taper steerer carbon blade fork. Sold with 28mm tyres but mainly so it doesn't scare off the 'fast flat-bar bike' buyer. I want to fit some M-bars and Nano 40s to one.
No reason not to use flat bars on an Arkose though. It'll be a bit shorter than some would like but stick to 90-110mm stem and use bar ends and it can work. The Arkose is already meant to work with shorter stems, 70-90mm.
Posted : 08/10/2016 7:15 pm
Thanks Jameso! I've got a size small arkose which has an 80mm stem so I'll consider getting a longer one. I've got some 680mm flat bars on order. Looking forward to seeing what it rides like.
Posted : 08/10/2016 7:58 pm
my mate does, and I did the conversion. He loves it.
Posted : 08/10/2016 9:50 pm
 thv3
I was also thinking about this, but I've got the 2016 Arkose 3 though which has flat mount disc brakes?
Can I fit "normal" post mount disc brakes with an adapter?
Posted : 08/10/2016 10:27 pm
2016 is post mount, so no prob there.
Posted : 08/10/2016 10:57 pm
Thanks Jameso! 🙂
Posted : 08/10/2016 11:01 pm
 thv3
Thanks Jameso!
+1 🙂
Posted : 09/10/2016 8:32 am
