Just got new bike with Pike Air u-turn fork and the adjustable travel is not getting beyond 125mm, any ideas?
If they are dual air, first thing to try is to release the air from the negative chamber (botttom of leg)
The more the neg air exceeds the pos air pressure, the less travel you are gonna get outta your forks
http://www.singletrackworld.com/forum/topic/fork-issues-rs-pike-is-mr-poddy-in-the-house
Does this sound like yours?
Yip dual air, so I'll try and drop the negative and see how I get on, cheers so far guys.
They're Air U turns IIRC Des, not dual air.
i have the same problem with mine even when there is 10psi less in the -ve.
sag is set at 25-30%.
iv,e give up ****ing around with them now.
tft next..
