Pikes lockout (or r...
[Closed] Pikes lockout (or rather lack of)
[#8106066]
Went to lockout my Pikes last weekend and the travel seems exactly the same whether in the fully locked or unlocked position.
Don't often use them locked, so I can't say whether this has happened suddenly or gradually
They're OEM forks on my Cube Stereo 140 if that makes a difference.
Any ideas for an easy fix, or is it a full service job?
Cheers.
Posted : 13/10/2016 1:09 pm
I don't think Pikes have a lockout (some newer models might).
That knob just adjusts high speed compression?
Posted : 13/10/2016 1:49 pm
It's may well be the air seal head has died and allowed air into the damper. If they're an older fork, you can retrofit the upgraded part from a newer Pike which should, after bleeding etc., sort it out. Straightforward swap for 650b and 29ers, more complicated for a 26" fork which also needs additional part fitted I think.
Those were the symptoms I had along with iffy damping. Fixed it myself following internet 'how to' guides. Fiddly in parts, but not really very difficult if you have a basic level of mechanical competence.
Posted : 13/10/2016 1:59 pm
Are they Pike RCs? Mine have never really locked out like my old RCT3s, the compression dial seems to do not a great deal of anything.
Posted : 13/10/2016 2:28 pm
Currently on Pikes after years of Fox forks, and am a little surprised at the lack of adjustment including lockout after years of CTD
Posted : 13/10/2016 4:24 pm
Are they the RCT3 damper?
There's a spring in the damper that can get misplaced and stop the "lockout" working. See [url= http://forums.mtbr.com/shocks-suspension/3-rides-rock-shox-revelation-lockout-not-working-817103.html#post10333296 ]here[/url].
Easy fix if it is - just need to unscrew the damper. It happened to me, and while I couldn't really see anything wrong, running my thumbnail around the spring made it click back into place, and all was well again.
Posted : 13/10/2016 4:46 pm
