Having trouble with the rebound on some 2016 Pikes. The red adjuster will only move about 4 clicks from fully slow. There booked in for a service in a weeks time but is there anything I could take a quick look at the get it working?
Remove the adjuster and clean it up as its prob a bit of shite that's gotten in. Easy to check the adjustments available with just a standard Hex key once its off. If you still only have 4 clicks... then just wait it out
I got the same issue. The rebound adjustment works fine with a hex key instead of the knob. I have tried the knob from my Lyriks which works perfectly! The knob is not easy to source so since mine are less than a year old, I sent them back.
