Pike coil conversio...
[Closed] Pike coil conversion and pedal platform
[#11740307]
Ive been running a Push ACS3 for a while in my older pikes none boost, 140mm , green spring, looks like 50lb, im about 170lb before my kit, i can only find the fox spring chart, and the green spring covers 170-185lb
I believe im on a charger 1 rct3
Im getting way too much bob when pedalling out of the seat, even in pedal mode.
pedal definitely stiffens it up but nowhere near enough. "locked" feels good to be out of the seat pedalling on.
would any of the later charger dampers improve this whatsoever?
Posted : 07/02/2021 10:51 pm
The pedalling mode is pretty similar ime... But then with my coil'd forks I don't use it anyway. Are you sure the spring rate isn't too soft- your fork's not exactly the same as mine but I'm about 25lbs lighter than you and using the same spring rate.
Posted : 07/02/2021 11:12 pm
well, that's what I thought at first, but when I looked it up, id be towards the min/mid of what PUSH recommend. so i was looking at maybe I need more LSC.
I wonder if its because im on a hardtail? rather than bob being partially absorbed in the shock, its all going to the fork.
i can buy a spring no problem
yer, there is absolutely no way i could even think about pedalling out of the seat in open as it is
Posted : 08/02/2021 12:03 am
