pike bottoming out ...
[Closed] pike bottoming out at half travel?
[#753942]
Was behaving as normal till end of ride, now its bottoming out half way through travel, only getting about 70mm travel, any ideas whats up, is it easy fix or trip to tft?
Thanks in advance.
Posted : 02/08/2009 2:39 pm
buggered seal between +/- chambers
Posted : 02/08/2009 3:07 pm
Forgot to mention these are coil forks, buggered seal would apply to air?
Posted : 02/08/2009 3:13 pm
no, buggered seal in damper.
Posted : 02/08/2009 3:17 pm
Warranty cover this is or am i gonna need pull em apart?
Posted : 02/08/2009 3:19 pm
If they're under warranty you'll need to return them to Fishers, usually via the shop you bought them from or a RS dealer. It sounds like there is a failure on the seal at the bottom of the damping chamber or an imperfection on the damping rod, causing a seal failure.
It could just be a bit of swarf keeping the seal open.
How much use have they had?
Have you used the Uturn with the lockout on?
Posted : 02/08/2009 3:22 pm
Hi trout, only bout 6 month old used once a week at most,never used the u turn tbh and never lock them out
Posted : 02/08/2009 3:24 pm
Warranty will cover it, but if you're comfortable with servicing forks then it's a motion control service which is fairly easy.
Posted : 02/08/2009 4:38 pm
Thanks everyone much appreciated!
Posted : 02/08/2009 4:45 pm
 nuke
Same as what happened to my Pikes. I went the warranty route: its been over a month since the fault occurred and they have been with CRC/Fisher now for three and a half weeks...still no news 🙁
Posted : 02/08/2009 4:46 pm
3 weeks!! bought mine from evans so doesnt look good does it, might be less hassle to do it myself, what seals do i need and where from?
Posted : 02/08/2009 5:07 pm
If I were you I'd get onto tftuned and get:
-motion control service kit
-lower lube kit
-250ml 5wt oil
Get the Pike service manual from the SRAM website. It will tell you what tools you need and what to do. Read it very carefully.
There's also some good vids on SRAM's youtube channel.
The wonderful world of DIY fork servicing awaits!
Posted : 02/08/2009 5:24 pm
And again many thanks for your help!
Posted : 02/08/2009 5:35 pm
I had exactly the same thing happen to mine a few weeks back. When I took mine back to the shop I was told they'd had 4 or 5 that week with the same problem, so it sounds like a bit of a common problem!
Mine was all fixed under warranty in under a week, but they didn't have to go back to Fisher leisure - I've been told there's only 2 guys there doing all warranty work for the Uk, which could explain the wait some people have had.
Posted : 02/08/2009 6:54 pm
@ delusional i see by your post on what 5-6 freeride bike you are riding a pitch, this is also a pike 351 on a pitch pro
Posted : 02/08/2009 7:22 pm
It is indeed.
Posted : 02/08/2009 7:24 pm
