Pike air loss issue...
[Closed] Pike air loss issues.
[#7017313]
Anyone else had issues with the loss of air?
Fork is solo air and after hitting a set of roots/rocks today lost all the air along with some grease from the outer side of the seal (as opposed to the stanction side If that makes sense)
Guess the air shaft seal has blown?
Typical, got a double pass out for both Saturday and Sunday!
Posted : 23/04/2015 2:32 pm
And it's a new type? Not the old 32mm version.
Posted : 23/04/2015 2:33 pm
Anyone?
Posted : 23/04/2015 7:29 pm
your right, somethings wrong. Time to send it for aervice and repair. TF tuned will sort or send it back if its under warrenty
Mine's running perfect since last March with one service before Xmas by TF.
Posted : 23/04/2015 7:44 pm
Il take them apart tomorrow and have a nosy.
Check there are no scores to the shaft and replace the seals and see how they go. Should sort it hopefully.
Just wondered if it was a common problem? Glad it didn't happen earlier on a fairly sizeable drop.
Posted : 23/04/2015 7:48 pm
