Pike 454 damper gri...
[Closed] Pike 454 damper grief
[#6752697]
Have got some olde Pike 454 coil u-turn forks that get used infrequently
The other day I dropped the lowers and cleaned them but when I came to refit the uppers the damper rod wouldn't stay extended. I could pull it out but when the end of the rod touched the inside of the lowers it retracted
Simple fix or do I need to get into the damper cartridge?
Ta
Posted : 06/01/2015 10:07 am
I've had this before, the way I fixed it was to open the cartridge, extend the pushrod, then close it again. I guess somehow there was air at a lower pressure inside the cartridge.
It's not a difficult job but IIRC it's a lot easier with circlip pliers.
Posted : 06/01/2015 10:26 am
