Pike 29er v Lyrik 2...
[Closed] Pike 29er v Lyrik 29er
[#8332884]
Hi
Considering my options. What are the real world differences?
Maybe buying the Boost version?
Steve
Posted : 06/02/2017 3:29 pm
Lyrik is stiffer, more suppportive, more composed and deals with trail chatter better. Lots of little advantages that add up to make it a much better fork.
Buy boost if your rear end is boost, then you'll have much better choice of wheelsets in future.
Posted : 06/02/2017 3:36 pm
We are running both and to be honest I cant tell the difference but I'm a light rider as is Abigale.
Also running some Ohlins which are by far plusher than the other two.
Posted : 06/02/2017 3:38 pm
I'm going to have a boost Pike 140 RCT3 29er for sale in the next few weeks off my 4 month old HighTower - probably ridden 12-15 times so in as-new condition.
Great forks but I'm a Fox man and so have some 160mm 36s incoming,
Posted : 06/02/2017 3:50 pm
hugh - if this is the case, then please drop me a mail
I'm close to getting a set of Yari but this could be better for me
cheers
Posted : 06/02/2017 3:54 pm
Hi
Might be interested as I have a160 air shaft
Not in a rush so a few weeks would be fine.
Email in profile
Steve
Posted : 06/02/2017 3:57 pm
I'l drop you both a mail (I think it only fair to give the OP first dibs) as soon as I have a date for the 36s.
Posted : 06/02/2017 4:30 pm
I've read that according to SRAM a Lyrik is the same stiffness as a 20mm shorter Pike, so 170mm Lyrik/Yari = 150mm Pike, if the wheel sizes are the same.
Adding a Luftkappe to a Pike will make it more plush than a stock Lyrik (by enlarging the negative spring).
Posted : 06/02/2017 4:34 pm
Cheers Hugh
Appreciate you replying - if fatgit doesn't want it I'll probably take it (unless I've sorted something else)
Many thanks
Posted : 06/02/2017 5:14 pm
Fatgit - YHM
Posted : 21/02/2017 4:57 pm
