PF30 removal tool
[Closed] PF30 removal tool
[#7608098]
Can anybody on here recommend a PF30 bottom bracket tool, I've chased them out freehand very carefully in the past but would really like a specific tool, I'm assuming that the same tool will remove BB86 cups aswell
I've been looking at the park bt303, the ones with the flared edges look a bit agricultural.
Thanks in advance
Posted : 27/01/2016 8:29 pm
One of these?
http://www.unior-bike.com/?doc=10780&prod=129857
I've got the bb92 version, works fine.
Posted : 27/01/2016 9:20 pm
I've tried one of those and it seems it only removes the actual bearings in a bb30 and not the pf30 cups, unless I got the wrong one?
Posted : 27/01/2016 10:56 pm
Headset cup removal tool
http://www.parktool.com/product/head-cup-remover-rt-1
Posted : 27/01/2016 11:04 pm
hammer and a punch do the trick?
Posted : 27/01/2016 11:40 pm
That's what I've been useing but I fancied something I little more subtle
Posted : 27/01/2016 11:48 pm
I'm interested in a comprehensive answer to this question toom, as I've now a need for servicing both BB types.
Park state that the RT-1 will do PF30 removal. PF30 caters for 30mm chainset axles. BB86 has a narrower bearing cup diameter so I'd expect the RT-1 to 'shrink' to fit but of course a narrower chainset axle accommodation at 24mm.
Is the shaft of the RT-1 <24mm? Might an owner be able to get a tape measure/verniers on their to confirm? It would be much appreciated!
Posted : 04/02/2016 11:07 am
