Im getting a cyclocross frame i was completely sold on the ON ONE dirty disco with standard
bottom bracket , until they have now introduced a new frame ( Planet x pro carbon XLS )
The DD has a standard threaded BB , but the new frame has a PF30 a little bit of research last night
told me that there are genuine haters of the PF30 bb system , but as usual when something new comes out
there are people how like it ( MTBR source )
Because most of the research last night was on MTBr , its left me wondering if the PF30 will hold up on a CX bike through a british winter
Opinions please
Thanks
Based on the nuber of PF30 BBs that we have returned due to creaking, I'd not touch one personally.
As another workshop monkey I can confirm the lifespan of pf30 can be measured in minutes. You can bet a BSA converter for pf30 though (and an eccentric bb aswell).
I dislike the PF30 on my bike, bottom bracket is 4 or so months old and on inspection whilst sorting out chainrings the bearings had no grease left in them and were notchy feeling already so popped some more grease into them to try and last a little longer. I will be looking at alternatives for replacement.
FSA IMHO make the best PF30 BB's at the moment. The none drive side has a double bearing seal, but you can't use a SRAM with an FSA BB and vice versa. Bit shite to be honest. Personally best to stay away from them.
Chris King are doing one imminently, may sort the problems.
What are the advantages of press-fit? It's cheaper to make. What are the disadvantages? You're relying on a friction fit on the most highly stressed bearing on a bike, and if it slips you can't just tighten it up again, you have to buy a new frame.
I really can't see why anyone in their right mind would use a press fit on a bottom bracket, but maybe that's the old-fashioned engineer in me speaking.
I rest my case. When you have to hope that a really expensive boutique bottom bracket will solve the problems inherent in the system, then it's a bad system.
What are the adapter systems like to use?. Are they stable?
SRAM bsa adaptor is straight forward enough...just remember to screw the bb BEFORE fitting it 😐
As others have said, press fit bb's are are pointless solution to a non existent problem, usually exacerbated by the laughably poor bearing quality fitted to them, you can swap out the bearings for "enduro" bearings which at least last a decent length of time in our climate but why design such a BB standard in the first place?....Oh....it's far cheaper for the frame manufacturers that's why.
Idiots!.
as well as reduced manufacturing costs, does it not give designers more flexibility in how they design the bottom bracket area allowing for more optimal levels of stiffness, weight, etc. Also they don't have to worry about the bonding of the BB shell in the BB area having to put up with the torque of loosening a seized BB with a large wrench and a length of scaffold pole.
I see your point brakes but as for seized BB's - that's down to mechanical ineptness in the first place due to lack of antisieze compound being used upon assembly and as for given designers more flexibility how about redesigning the entire BB shell to incorporate larger axles and inboard bearings, narrowing the "Q" factor for increased pedalling efficiency would be nice as well.
.Also they don't have to worry about the bonding of the BB shell in the BB area having to put up with the torque of loosening a seized BB with a large wrench and a length of scaffold pole
But surely they have to counter that with worrying about how you remove the bearings - basically a dirty great hammer smacking away at a drift on a bearing that doesn't want to move?
I've got a PF30 BB on my bike and have to admit I was a bit peeved when I found out it had one as it meant I couldn't do the BB fitting myself and would probably have to pay for it, if it was to be done properly.
Reliability wasn't really a consideration, especially given the bad press outboard bearing BBs get anyway.
I've not had any problems with it yet, but then it's only had a few rides.
Have being Useing the praxis works comverter in my salsa frame it's lasted far longer than any pf30 I've tried
But and maybe it's me being odd I prefer internal bbs but it does Limit choice a little now
