Does anyone know if spindle sleeves (the plastic inserts) are specific to bottom bracket maker on PF30's ie. If replacing a a SRAM PF30 BB with a Chris King one are the spindle sleeves universal (I will be refitting the SRAM 1250 chainset).
Posted : 12/04/2018 10:16 am
I've only encountered these on the newer sram pf30. They certainly aren't used for wheels manufacturing pf30. I would suspect that hope, Chris king etc don't use them either. If they use a 30mm inner diameter bearing then they won't be required as your sram spindle is 30mm.
Posted : 12/04/2018 12:20 pm
