managed to loose some of the pedal washers for my lx cranks - if I'm careful fitting the pedals will I be alright - or are they essential to stop threading the crank?
Posted : 31/01/2010 8:32 pm
My understanding was that they just protected the surface between the pedal and the crank, important if you regularly change pedals. So long as you can screw the pedal in a few turns by hand before using the spanner, you should be alright.
Posted : 31/01/2010 8:38 pm
