Peaks climbing
[Closed] Peaks climbing
[#5937328]
Comparing a loop around Nant Yr Arian to a loop around Jacobs Ladder on Strava,
Its clear there's a fair amount of climbing to be had in the Peaks,
Will be a long overdue first visit this weekend,
Am I going to die?
Posted : 10/02/2014 9:50 pm
Hypothermia probably. Or drowning. So basically, yep.
Posted : 10/02/2014 9:56 pm
Death could be arranged - depends on your route 🙂
The Hayfield - Edale Jacobs ladder circuit is a good example of a rel short ride (think it's about 15 miles) that packs a fair wallop.
Find part of the challenge is that most of the popular bw climbs are all quite makeable (Jacobs ladder being a famous exception) - so you find yourself grinding up loads of them on a long ride and you're wrung out by the end.
Posted : 10/02/2014 9:58 pm
Which is the best way round the Jacob's / Roych loop? 😉
Posted : 10/02/2014 10:03 pm
Up from Hayfield, down Jacob's.
Although it used to be better the other way around. Having said that, I've not ridden it since they did the last bit of work on roych.
Posted : 10/02/2014 10:06 pm
Puddles cant be any worse than the Ponds littering Sherwood Pines!
Is it worth riding at this time of the year?
Posted : 10/02/2014 10:09 pm
I'd say so. Done it in th snow and sleet a few times. Come up chapel gate though and miss out rushop edge. Not fun and not clever to try and ride that at the moment.
Posted : 10/02/2014 10:14 pm
Climb per mile isn't too bad in the peak. I average around. 2000m in a 65-70km ride. That's usually taking in a fair amount of hills.
More climb per km in north Wales in my experience.
Posted : 10/02/2014 10:25 pm
A fine job they have done to be fair. Should be used as the benchmark for all future work if you ask me.
Generally speaking, Hollins Cross and Rushup have all been pretty muddy over the last few weeks, can't imagine they've improved. The drier option of going up Chapel Gate is quite boggy at the top assuming you don't die of boredom getting up there. 😈
Posted : 10/02/2014 10:37 pm
I've done peaks rides which are 1000m of climbing in 15km. So yeah, you can ride a lot of height if you're trying. That was a ride which essentially included no flat bits at all 😆
Rode the Chapel gate/Roych/Jacob's loop last weekend. Not bad nick, a few puddles but mostly OK. Just some muddy pools around the gates here and there, and it had uber-pissed it down the night before. It's a good all-weather route.
It's a good thing you like climbing if you're planning on going up Coldwell Clough 😯
EDIT: Actually, thinking about it, crossing the top from Chapel Gate was a bit like navigating the Dead Marshes. Remember, they're not as deep as they look (I think).
Posted : 10/02/2014 11:47 pm
 Spin
Am I going to die?
Yes. There is a crowd of pedants coming to stab you right now for calling it The Peaks when it is The Peak.
Posted : 10/02/2014 11:52 pm
"Jacobs ladder being a famous exception"
Its suprising just quite how much of it IS rideable though, just keep getting back on and trying to get through it. Similar to the upper sections of Coldwell clough it'll try damn hard to make you dab.
Really its only the really steep steppy part near the top of Jacobs that its properly properly difficult imo. The rest will go with a chunk of manic pedalling and a load of luck to panic-steer yourself through the rubble
Also nearly at the very top theres a double step up out of the gully bit that I've always get the weighting wrong and my rear tyre spins out on.
Posted : 11/02/2014 12:47 am
Looking to do the up Chapel Gate/Royce Clough/Edale Cross and down Jacobs loop on Friday leaving from the Edale car park.
I have done it once before and was alittle under the weather but really struggled with the climbs... humbled me a bit to be honest...
Posted : 11/02/2014 4:51 am
I quite happily throw all my man points in a field at the bottom of Chapel and walk up. If someone told me I had to ride up Jacobs, or become a girl, just call me Dorothy!
Posted : 11/02/2014 5:31 am
I must be one of the few not to have tried riding up Jacobs ladder, it's so much fun in the other direction 🙂
Posted : 11/02/2014 5:39 am
I'd like to ride Jacobs more, put a wee dent in it, but just can't be arsed with that first section. It's not super steep, but you're riding through loads of large, loose rocks - dab city. Seems like even an expert would need some luck to clean it. After that it reverts to a completely ball-busting climb but at least the surface is ok.
The big left hand corner just before the footpath comes in on the right also seems super hard, for those with designs on clearing the whole thing.
Posted : 11/02/2014 9:34 am
Ridden Jacobs both ways many times but going down is a hoot while trying to climb it just frustrating.
Re The Peak compared to Nant y Arian: trail centres are great but climbs are designed to be ridden by all but the most lethargic - the Peak trails were designed to be ridden by pack animal so present a different challenge. F'rinstance Nants Legburner is just a long road climb, Jacobs & many other rocky climbs are technical. The climb out of Coldwell is a biatch as is the approach to Jacobs.
If you've never ridden the Peak you really must!
Posted : 11/02/2014 7:47 pm
Don't mind a new challenge.
With 1x9 this is what worries me.
Posted : 11/02/2014 9:02 pm
I was going to ask, do the people who ride these climbs have a granny ring?
I feel I have ZERO chance of riding up Jacob's with my 9 gears.
Posted : 11/02/2014 10:27 pm
There are few people even with a low enough gear that'll ride up Jacob's.
Posted : 11/02/2014 10:35 pm
 mrmo
jacobs isn't hard as in needing a granny gear, that might make it even worse, it is hard because it is lots of loose rocks that move around under you for the first bit.
The second bit is easy, then the final bit with lots of rock slabs is just unpleasant and not a lot of traction.
Yeah exactly. The first bit is easier if you (can) go a bit faster - granny ring won't help here. The only bit where it would be useful would be to chill out on the flat-ish bit before the last push for the top. In fact I don't think 1x10 is especially limiting on technical climbs in the UK - a bit of extra speed is always helpful and you won't get up the harder stuff by trundling along in granny gears.
Is anyone going to claim it - riding up Jacob's? Often talked about but I don't know anyone who has actually done it. It's one of my riding ambitions for sure. But whether I will ever get there I don't know...
Posted : 12/02/2014 12:45 am
I did a photshoot once with a rider who rode it all in bits. He'd previously done it all with no dibs though.
This fella. 😉
[url= http://farm5.staticflickr.com/4108/5048653938_7b963ceb5e.jp g" target="_blank">http://farm5.staticflickr.com/4108/5048653938_7b963ceb5e.jp g"/> [/img][/url]
Posted : 12/02/2014 1:04 am
Pfft, riding it in bits doesn't count. Tell him to GTFO whoever he is 😉
Posted : 12/02/2014 1:09 am
This fella.
Nick Craig. I read an article in Another Magazine about him clearing Jacobs.
Saw him riding there last year - least I think it was him, not many people riding there on drops 🙂
Posted : 12/02/2014 8:47 pm
Just thought I'd report back after my first couple of experiences in the Peaks,
It's tough, The climbing that is, I like a nice welsh fire road climb, sitting back and just pedal!
The Peaks demands more from you, I find one of my issues is struggling to get back on pedalling on the more technical climbs, using my 1x9 32t X 11t-32t it feels like I'm putting too much power to gain stability,
often the front wheel is jumping up,
From what others here have said I'd be better swaping my cassette for a 12t-36t rather than dropping my 32t chainring for a 30t?
Anyways, The humbling climbs aside, the descents are awesome,
OK it's no purpose built trail centre trail, its not smooth, it's often testing but thats what I like about it,
It makes you ask questions about your riding, it puts you in the corner and asks you to fight,
After only two visits I've come to the conclusion that if you can handle the Peaks, you'll be able to handle most things in this country but then again, I've not been all over.
I like the Peaks, I'll be heading back for my third encounter tomorrow.
Also can anyone let me know of this gnarly descent coming back down to Hayfield?
We came down round Mount Famine, headed through the double gates but just ended up on a pretty boring track/road, There was a footpath to the right?
Is this the one? of course been a footpath,I'd never ride it!
Posted : 13/04/2014 1:23 pm
There is only one of them! It's the Peak District, ok so there is the white and the dark peak but it's still the peak District.
Anyway the riding is awesome there.
Posted : 13/04/2014 1:31 pm
Anyway[b]s[/b] the riding[b]s[/b] is awesome[b]s[/b] there[b]s[/b]
wastes of times correcting thats theres peaks things. 🙁
Posted : 13/04/2014 1:36 pm
I'm new to the Peak District, you'll forgive me!
Posted : 13/04/2014 1:37 pm
Thanks guys.
Posted : 13/04/2014 1:39 pm
It depends what you mean, but if it's the right turn at a crossroads, [url= http://streetmap.co.uk/map.srf?X=404995&Y=385350&A=Y&Z=120 ]here[/url] - then it's a bridleway and heads down Coldwell Clough, wide, rocky descent, holes and drainage bars. Then left up and down behind the campsite, aka 'the campsite descent'.
Posted : 13/04/2014 1:46 pm
It depends what you mean, but if it's the right turn at a crossroads, here - then it's a bridleway and heads down Coldwell Clough, wide, rocky descent, holes and drainage bars. Then left up and down behind the campsite, aka 'the campsite descent'.
That's the one!
Is it as good as hear it is?
Posted : 13/04/2014 1:55 pm
It's a decent Peak descent, yes. And a legal one. There are some interesting new-ish erosion gullies on the lower bit of Coldwell Clough that you need to watch out for and the campsite descent is turning into quite an interesting trail nadgery then rocky at the top, fast an open, then back under the trees. But if you're asking, is it worth doing, the answer's yes 🙂
Watch out for wandering shaggy highland cattle though...
Posted : 13/04/2014 2:03 pm
Come across those cows a few times, a little bit of poo came out one night ride when one was stood right round the corner on the corner.
Posted : 13/04/2014 2:08 pm
If you drop into Coldwell you can then climb out toward Kinder.
You have two options on the climb: Either stay on the main track, keep on climbing & then descend Jacobs Ladder.
If it doesn't make you smile you're dead.
There again the smile could be the effect of rigor.
Or you can take a bridleway on the left (the sign's been missing for some time, dunno if it's replaced yet) which will take you to a descent to Kinder Ressie.
At the ressie you can either take the road back to Hayfield or take another biatch climb to the shooting cabin on Middle Moor (On a clear day you can see this from Mt Famine). From there it's downhill bridleway to Hayfield. This can be popular with walkers in fair weather.
Anyway, back to your original post: Yes, climbing in the Peak is different to trail centres. Their climbs are groomed to be possible by the average.
Much as I enjoy trail centres give me the Peak any day. When I get back there after a few trail centre sessions it makes me realise how tame most are.
(wanted to do Cut Gate today but figured it might still be messy and would be windy)
Posted : 13/04/2014 2:41 pm
32 front to 32 rear is 25.9 inches
32 front to 36 rear is 23.1 inches
30 front to 32 rear is 24.4 inches
using [url] http://www.bikecalc.com/gear_inches [/url]
so existing front with a 36 rear gives about 5% more something for the effort than swopping the front which isn't a lot but if able to power thru then ok - suspect people doing technical "natural" ascents are running much smaller front rings
sure some people on here more expert and will come along soon
edit personally I run a trad triple and 22t granny with a 34t rear - so that can make me too slow on the more tech ascents
too slow to blast thru or maybe it means I just keep going when I hit stuff ?
Posted : 13/04/2014 2:43 pm
Yeah - I run a 22x36 on my 26 and have just fitted a Hope 40T to my 29er so with it also having a 22 front the ratio will be about the same.
These are bail-out ratios but I'm old.
Wouldn't even consider those ratios for trail centres.
Mind you I've seen people pushing single ring jobbies in Cannock.
I struggle with that one. If you're fit enough to run a single ring for your choice of riding then great. If not take advantage of technology.
People died to give us double clangers and triples.
Why die of a heart attack in the pursuit of fashion? 😯
Posted : 13/04/2014 2:54 pm
It's more a financial reason but I seem to be coping, I'll switch to a 12-36 to help.
Posted : 18/04/2014 2:26 pm
 br
[i]I feel I have ZERO chance of riding up Jacob's with my 9 gears. [/i]
If you ain't fit enough to ride a with 1x9, you need a granny ring.
Posted : 18/04/2014 2:48 pm
