Have used Panaracer XC Pro's for some time now. What is the equivalent /similar tyre from other manufacturer's?
I used to use XC Pros even after they became decidedly unfashionable because I liked the predictability. I moved on to Maxxis Ignitors and I like those for the same reason.
I have used them in 26" 27.5" and 29" versions all year round on the front, although in the summer I tend to use a lower rolling resistance tyre such as an Aspen on the back.
I use 2.35 on the front, 2.1 or 2.35 on the rear
I would go for something a bit faster/wider/more capable. So things like Rocket Rons snakeskin 2.25, Barzo 2.2, x-king protection 2.4 - that sort of thing. Fast, but ok in a bit of muck.
You are in for a treat if XC Pro's are your current tyre....
Have always used 2.1 on the front and back. What differences should I expect going to say 2.35?
Lower pressures, so more tyre deformation over the bumps = smoother and faster ride. Also more grip as the contact patch is bigger. You also need less tread for the same amount of grip.
This.
OP - where do you ride, and what kind of riding?
Its a 50/50 split between roads and grassy hard pack byways. Nothing extreme at all.
in that case I'd stick to 2.1's personally
Had XC pros for a while...back in 2005. They're just OK, every tyre i've had since then has been better. For something XC-ish I love a WTB Bronson, maybe an Ardent for the rear?
Aye, you want something quickish, Rocket ron, ardent, that sort of thing.
Ok then 2.1 or 2.0s will be fine. Get something like a fast-trak, saguaro, race king etc.
In which case, whatever tyre you can lay your hands on in a cheapo sale that is lightish, flexible and a smaller tread.
2.1 Thunderburts for that kind of riding
^^ wot he said.
I'm currently using 2.1 Thunder Burts for riding road/ gravel/ singletrack/ bridleway/ general stuff. They've been very predictable and are fast and surprisingly grippy.
Second the wtb Bronson. Don't know if anyone sells them now.
They are fast and drifty in a controlled way. Lots of fun.
Still have fire pro on my old kona and do a decent job. Think they are ten years old!
